running a workbench using python
  • Oct 22, 2019 5:58 PM UTC
  • 147 views
tnarladni
Forum|alt.badge.img+24
I would like to run a workspace using python and the code I have is simple, but it's not working. Is there something wrong with my python code or could it be something else?
import subprocess
args = [r"C:\Program Files\FME\fme.exe", "C:\ProgramData\Geocortex\Workflow\FMEScripts\testEmailer.fmw"]
subprocess.Popen(args)
Best answer by tnarladni
I found the problem. It was the syntax. So this thread has a similar line of code, but I noticed that the second argument has double backslashes and no r.
https://knowledge.safe.com/articles/1158/run-an-fme-workspace-from-python-using-fmeworkspac.html
So I tested and found that either I need to put 'r' before the literal string for the path, or escape the '\' with '\\'. And that worked. so here is my new code and this is working.
import subprocess,os,getpass
args = [r"C:\Program Files\FME\fme.exe", r"C:\ProgramData\Geocortex\Workflow\FMEScripts\testEmailer.fmw"]
jdh
Forum|alt.badge.img+41
  • Oct 22, 2019 6:00 PM UTC
You are missing a couple of arguments, like the path to the workspace to be run and optionally any published parameters.
tnarladni
  • Oct 22, 2019 6:02 PM UTC
oops. I posted the wrong code. I edited the question to show my py script
jdh
  • Oct 22, 2019 6:25 PM UTC
I've never used subprocess to run an fme workspace. There is an article on using fmeobjects and the FMEWorkspaceRunner.
tnarladni
  • Oct 22, 2019 6:41 PM UTC
