Run oracle procedure via python shutdown script
  • Aug 1, 2013 2:10 PM UTC
  • 83 views
fmelizard
Forum|alt.badge.img+22
Hallo all,
I need to make sure that my procedures (enabling triggers and constrints) are run at the end of my translation.
Since I have no idea if any of my writers will be triggerd I cannot use the end sql.
After googling I came across the following module (cx_Oracle), but I dont know how to use it with procedures, or if it is at all possible.
Any assistance would be helpful.
Itay
fmelizard
  • Aug 2, 2013 8:24 AM UTC
well, I have decided that te end sql is useful, since each writer can be connected to a start and end sql. this way the procedure is run before and after database interaction.
  • Aug 2, 2013 11:29 AM UTC
Hi Itay,
does this mean that you found a solution?
In any way, here is the documentation for the cx_oracle module:
http://cx-oracle.sourceforge.net/html/index.html
David
fmelizard
  • Aug 2, 2013 12:42 PM UTC
Hi David,
I ahd a look at it before, thanks anyway.
Yes the start\\end SQL is my solution.
Have a nice weekend.
