Hello FME community, I have a workspace which I always run with quick translator. Since my user parameters are never going to be changed, is there a way that I can simply double-click on this file and it runs with quick translator without the need to click OK or press Enter to confirm the user parameters?
run on quick translator just by double click?
Best answer by nielsgerrits
I think not. What you can do is to create a .bat file to run the workspace commandline with parameters. The instructions are in the first lines of the log when you run it in Form. Something like:
Command line to run this workspace:C:\apps\fme_2023_2_2\fme.exe "C:\Temp\New folder (28)\none2none.fmw" --Integer "4" --FME_LAUNCH_VIEWER_APP "YES"
Also see
https://support.safe.com/s/article/batch-processing-method-1-command-line-or-batch-fi
and
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
