Restore SQL.bak file from FME script
  • May 23, 2024
  • 77 views
dustin
Forum|alt.badge.img+31
We have a SQL .bak file which serves as a template for a database schema. Normally this .bak is restored manually via MSSQL, where the name of the database is specified.
The goal is to be able to dynamically create a database on a known server, where the name of the database is derived from processing within the FME workspace.
Is there a script that can be run from a SQLExecutor in FME to make this possible?
virtualcitymatt
Forum|alt.badge.img+35
So this article seems pretty helpful:
https://www.ubackup.com/enterprise-backup/sql-restore-database-from-bak-file-1021.html
For the the best answer for you in there is:
By running:
RESTORE DATABASE databasename FROM DISK = 'filepath\filename.bak'
Seems like this should work from an SQLExecutor
