Reprojection faliled
  • November 21, 2023
  • 7 replies
  • 49 views
checcosisani
Forum|alt.badge.img+14
Hi
I need to reproject from EPSG 7791 to wgs84 but I received an error
I use data interoperabilit 3.2 with reprojector engine ESRI
can you help please ?
thx
Francesco
takashi.home
Forum|alt.badge.img+3
  • November 21, 2023
Hi @checcosisani​ ,
Can you please post a screenshot illustrating the Reprojector parameters setting?
checcosisani
  • November 21, 2023
Hi @checcosisani​ ,
  • November 21, 2023
The red background of edit box means that the parameter setting is invalid.
Since you have chosen Esri Reprojection Engine for the workspace, a coordinate system name may be different in FME 2023.
Try setting again appropriate coordinate system name.
I think this screenshot illustrates your intended setting - equivalent to EPSG:4326.reprojector-parameters
checcosisani
  • November 21, 2023
Yes I know but epsg code aren't standard ...
Why esri and fme aren't align ?
Thx
Francesco
topf
  • November 22, 2023
Thx
Francesco
Safe (FME) are actually aligned with https://epsg.io/ so it's Esri that would need to adjust here 😄
checcosisani
  • November 22, 2023
Yes I know .. this is the reason why FME is best in class 🤙
Thank you for the link.
In my case it it working fine. thanks again. For seamless coursework creation https://www.topessaywriting.org/coursework-writing-service Coursework Writing Service' is the compass guiding me through academic challenges. The platform's dedication to delivering quality coursework showcases their understanding of students' needs. A reliable partner for academic success!
