Replace string value NOT matching regex, else <null>
  • Jul 12, 2022 12:35 PM UTC
  • 481 views
townest
Forum|alt.badge.img+4
Hello,
In one field, I want to keep all string values matching the regex:
\\d{4}-\\d{2}-\\d{2}
and relegate all strings NOT matching that string to:
<null>
See following image for my attempt where I developed ^(?!\\d{4}-\\d{2}-\\d{2}).* as the negation of \\d{4}-\\d{2}-\\d{2} and set replacement to <null>. This did not work.
foot_surv_fmeAny pointers would be greatly appreciated!
Tyler
Forum|alt.badge.img+54
  • Jul 12, 2022 12:50 PM UTC
You could do something like this, test if you get a match on the regexpression (this returns 0) then set the value to null if no match is found
townest
  • Jul 13, 2022 12:27 PM UTC
Thanks @ebygomm​ , that got me on the right track. I ended up using your concept, modified a bit, and in an attribute manager so I could take care of other attributes simultaneously. Here's the result.
imageTyler
