Hello,
FME Flow announces the deprecation of the JobWaiter transformer:
- 2024-9-2 10:59:42 | FMEFlowJobWaiter (ServerFactory): FMEFlowJobWaiter was deprecated in 2024.1.0. Its support lifetime is limited because the v3 FME Flow REST API will be removed in future FME releases. When the v3 API is removed, this transformer will stop working. Please update this workspace to use an HTTPCaller to call the relevant REST API directly instead.
Question: Is there any ‘how-to’ with a sample workspace which REST call can be used to replace the JobWaiter functionalities? My sample scenario would be: You have 5 jobs running in parallel (wait to complete NO), JobWaiter polls every 20sec until all 5 job_ids are received and completed. all 5 jobs must have _status SUCCESS before Job #6 is called.
I tried GET /transformations/jobs/id/{jobid}/result but it failed with 404.
Any hint?
thanks
Klaus
