Rename featureclass coming out of feature reader
  • Sep 2, 2018 11:14 PM UTC
  • 194 views
I am using a featureReader and dynamically writing to a writer.
The problem is "BuildingExtent" needs to be replaced to "BuildingFootPrint". This is because the featureclasses are differnt for only that featureclass.
Any solution to replace them?
nielsgerrits
Forum|alt.badge.img+67
The way I do this is to replace the "fme_feature_type_name" attribute in the Schema Feature flow and replace "fme_feature_type" in the Feature Flow:
changefeatureclass20181.fmw
  • Sep 3, 2018 2:59 PM UTC
You can just apply Feature Type Fanout if you set "fme_feature_type" to the Schema Definition Name explicitly. e.g.
nielsgerrits
Even better, didn't realize it works this way. Thanks, learned something new today.
