Removing Attributes with a dynamic writer from specific tables
  • Nov 30, 2016 12:18 AM UTC
  • 108 views
jackyd
Forum|alt.badge.img+16
Hi
I am using FME to transfer data from Oracle to PostGIS
For a couple of my tables I don't want to include some fields, however some of the fields to be removed have the same name as fields on other feature types that I want to keep.
Can I specify which table to remove the attribute from in the dynamic writer properties?
Thanks
  • Nov 30, 2016 1:19 AM UTC
Hi @jackyd, you can create multiple dynamic writer feature types with different configurations for a single writer, so if you branch the output data flow into two streams according to a condition such as source table name (fme_feature_type), you can write them into the destination dataset with two dynamic writer feature types - one for keeping the fields and another for removing the fields.
Hope this helps.
jackyd
  • Nov 30, 2016 5:32 AM UTC
Thank you @Takashi, don't know why i didn't think of that, this will be prefect.
  • Oct 9, 2017 11:53 AM UTC
Hi @takashi,
I am translating the DWG file to File Geodatabase and getting problem of managing attributes in Dynamic Writer.
I am unable to control the attributes using attributekeeper or attribute remover or any other way.
Kindly suggest me a way-around.
