Remove empty attributes in Data Inspector
  • Dec 22, 2017 6:14 PM UTC
  • 52 views
Is there a way to have the data inspector not show attributes that are empty? When looking at AIXM 5.1 data, the tables is filled with empty attributes and makes it hard to 'inspect; your data
mark2atsafe
Forum|alt.badge.img+59
If it's the table view (and 2017) look to the top-right of the table view window for a button labelled Columns. With that you can remove columns that are completely empty.
mark2atsafe
The filter tool doesn't work on the table view, so unfortunately you can't use a filter to drop rows (features) with missing values (although you can drop them from the main view).
  • Dec 22, 2017 9:17 PM UTC
Yeah but with AIXM there are A LOT of fields to sort through. I was hoping for a button that would do it in the table view much like Feature Information view only shows the attributes that have values.
