REGEX support
  • Oct 19, 2023 1:54 PM UTC
  • 62 views
checcosisani
Forum|alt.badge.img+14
Hi
can you help me to find the correct regex to extract only the string in bold (ALESSANO)
\\\\199.168.30.208\\dati\\pippo\\PUGLIA\\ALESSANO\\INGRESSO\\ALESSANO\\tracciato unico.shp
thx
Francesco
birgit
Forum|alt.badge.img+25
  • Oct 19, 2023 2:18 PM UTC
You can use stackoverflow for this. Also do you just want ALESSANO or du you always want the value between the second to last \\ and the last \\.
Also can't you just use the FilenamePartExtractor transformer for this kind of stuff.
dustin
Forum|alt.badge.img+36
  • Oct 19, 2023 2:21 PM UTC
If you want the directory the shapefile resides in, I would consider using the FilenamePartExtractor. Passing that string will result in a _dirname attribute.
  • Oct 19, 2023 2:41 PM UTC
I would skip using a regex for this, simply for the reason that it gets a bit unmaintainable unless you're already familiar with it. The FilenamePartExtractor is my preferred solution.
For fun, you could also simply use an AttributeSplitter followed by a ListIndexer. This has the added bonus of giving direct access to all the individual folder names:
  • Oct 22, 2023 1:07 PM UTC
Hi @checcosisani​ , I agree that FilenamePartExtractor is a better solution in this case, but if you would like to know a regular expression to extract the interest part anyway, try this regex with StringSearcher.
