Reg : Could not open SDE workspace using FME Python
  • Aug 11, 2014 3:35 PM UTC
  • 147 views
Hello,
I am trying to disconnect users of SDE using python . When I use the below code
arcpy.DisconnectUser(arcpy.env.workspace, "ALL")
arcpy.env.workspace = r"C:\\Connections\\SDE.sde"
I am getting an error  Python Exception <TypeError>: Could not open SDE workspace.
Has anybody encountered this error ? Any Ideas ?
  • Aug 11, 2014 4:19 PM UTC
Make sure to test the value of arcpy.env.workspace separately (if it's a connection file, try it using ArcCatalog, etc).
Also be aware that the connected user must have admin privileges in the database, more info here (http://resources.arcgis.com/en/help/main/10.1/index.html#//002q000000r8000000).
David
  • Aug 11, 2014 4:26 PM UTC
Hello David,
The Connection File works fine . I can connect using Arc Catalog also I can connect it using python Idle
The connection has administrative privilege.
Our SDE has Oracle as Backend Database
  • Aug 12, 2014 6:38 AM UTC
make sure that the connecting user has ALTER SESSION rights in Oracle.
If that doesn't help, I suggest perhaps also asking in an ArcGIS-forum.
David
