PythonFactory failed to load python symbol `FeatureProcessor'
  • February 20, 2018
  • 1542 views
kartemann
Hello,
I'm trying to use an external python library, Paramiko to perform some SFTP functionality. I am attempting to use a PythonCaller to run some python that I know works outside of FME. I have python 2.7x64bit installed. I'm running FME 2017.1x64 bit. My python interpreter is set as below:
Here is the PythonCaller configuration:
Here is the python script:
And here is the error:
I'm sure i'm goofing up something simple. Thank you for your help!
Best answer by takashi
Hi @adamradel, because your Python Script doesn't contain a class named 'FeatureProcessor'. If you intend to call the function 'processFeature' here, change the 'Class or Function to Process Features' parameter to the function name to be called.
  • February 21, 2018
kartemann
  • February 21, 2018
Thank you very much @takashi! That did the trick.
