PythonCaller: howto expose "unknown" attributes
  • June 12, 2013
  • 117 views
I wrote a script that calculates something with some attributes of a dataset and stores new attributes, something like
for AttributeName in MyFMEObject.AllAttributeNames()
  if AttributeName[:6]!='LIST_'
    MyFMEObject.setAttribute("MAX_"+ParamAttributeName,-1)
    MyFMEObject.setAttribute("MIN_"+ParamAttributeName,1000000)
  if AttributeName[:6]=='LIST_'
    CalcMaxMin(AttributeName[-8:])
    MyFMEObject.removeAttribute(AttributeName)
def CalcMaxMin(ParamObject, ParamAttributeName):
  localValue=ParamObject.getAttribute(ParamAttributeName)
  localMaxValue=ParamObject.getAttribute("MAX_"+ParamAttributeName)
  localMinValue=ParamObject.getAttribute("MIN_"+ParamAttributeName)
  if localValue<localMinValue:
    ParamObject.setAttribute("MIN_"+ParamAttributeName,localValue)
   if localValue>localMaxValue:
    ParamObject.setAttribute("MAX_"+ParamAttributeName,localValue)
it is shortened and only a not tested example, in reality I split the listnames in parts (cause it is not a list in python- style, is it?) and do some more.
from Attribute MYVALUE1, MYVALUE2 ... I created
MAX_MYVALUE1, MIN_MYVALUE1, MAX_VALUE2 ...
how can I publish this for next transformer, if I do not know at design time, what Attributes I get?
Best answer by david_r
You can only expose attributes known at design-time, as far as I know. So no luck, I'm afraid.
Your best bet is probably to set your attribute names to a list or a group of attributes with fixed names.
You might already know this, but you can create lists dynamically in a PythonCaller with something like:
for n, value in enumerate(mylist):
    feature.setAttribute("MyList{"+str(n)+"}.Value", value)
where you expose "MyList{}.Value" in the PythonCaller config. You can then use the ordinary list transformers in FME to access all the values in the list.
David
  • June 12, 2013
David
  • June 28, 2013
I did not try this. It seems to me that there is a methode "Publish" missing.
In my case I needed this once (for abot 20 attributes, was a copy/paste - orgy) and I can not make a "useful" custom transformer.
By using the Lists it probably would be possible to build such one, but the usebility of the list elements is not that easy, as I would like. If I understand it correct the transformer would do like this:
For all Fields A,B,C ... should be created MaxA, MinA, AvgA, ... AvgC ...
I could say ListMin, ListMax, ListAvg are published and I would create
ListMin[0].A, ListMin[0].B ...
and had manually to create in a following transformer
MinA=ListMin[0].A, MinB=ListMin[0].B ... AvgC=ListAVG[0].B
So I have - depending on the number of fields - a lot of manual work.
But thank you for your answer, I try this next time.
Andreas
  • April 1, 2015
Hi knowing ones,
Is there a way now?
Another matter same question.
There is a database and something like
SELECT TABLE_NAME,ID FROM MY_SPECIAL_VIEW;
TABLE1, 12345;
TABLE1, 23456;
TABLE2, 34567;
and in the python caller I need to read the information as
SELECT * FROM TABLE1 WHERE ID = 12345;
ID = 12345;
NAME = "Hello";
ADDRESS = "World";
WSXDR = "YSEDC"
And I need to expose the Attributes ID, NAME, ADDRESS and WSXDR and maybe a control structure as MyDict {TABLE1:(ID,NAME,ADDRESS,WSXDR)}
Later I need to create a layer for each table in which are only the rows of this table with the correct content.
If I can't do this automatically I must build a special way for each table what is much work at once and I need to take care for every changing of the DB- Structure.
So I hope there is a dynamic/generic way that I can go.
Thanks in advance
Andreas
