Python Shutdown script not executed
  • Dec 10, 2015 10:29 PM UTC
  • 11 replies
  • 150 views
erik_jan
Forum|alt.badge.img+26
Anybody an idea why this combination would not work?
The Shutdown script seems to not executed.
Startup script
def initializeArcFM():
import win32com.client
global app
app = win32com.client.Dispatch('Miner.Framework.Dispatch.MMAppInitializeDispatch')
runtime = win32com.client.Dispatch('Miner.Framework.Dispatch.MMRuntimeEnvironmentDispatch')
app.Initialize(0x5)
runtime.RuntimeMode = 0x4
print "ArcFM runtime mode", runtime.RuntimeMode
def cleanupArcFM():
global app
if app:
app.Shutdown
del app
print "ArcFM shutdown"
initializeArcFM()
Shutdown script
cleanupArcFM()
Best answer by erik_jan
Hi All,
Thanks for the huge amount of ideas.
Safe support (@LauraAtSafe) figured it out after all:
The problem was in the FME Server engine reloading Python after each run.
This caused the script to fail the second time it was run on the same FME Server engine.
The solution was in setting the FME Server setting FME_ENGINE_PYTHON_RELOAD to false.
This issue was solved in FME Sever 2015 and should not appear anymore.
So the Python script in itself was working as designed.
Thanks again.
Forum|alt.badge.img+5
  • Dec 12, 2015 9:08 PM UTC
Can you format your code please ? or a screenshot in FME Desktop.
Where is the error in log file ?
cleanupArcFM is defined in Startup Script and you call your def in Shutdown script. May be the best thing is to put the same def in Shutdown script
fmelizard
Forum|alt.badge.img+22
  • Dec 12, 2015 10:54 PM UTC
Yes the log should be interesting. The only way we wouldn't invoke the shutdown python is if the whole translation were going down hard.
  • Dec 14, 2015 8:24 AM UTC
I agree with the others, you need to post the formatted code, as indenting is meaningful in Python.
Having said that, you could probably simplify your debugging a fair bit by dropping the function definitions and just doing everything line-by-line, in a sequential order. Would probably look something like this:
app.Initialize(0x5)
if app:
    app.Shutdown
del app
David
erik_jan
  • Dec 14, 2015 4:42 PM UTC
Sorry about the lack of indentation (I know it is important, but it fell away copying it from an email).
Here is the better text:
The FME log shows this Error:
Python Exception <TypeError>: 'NoneType' object is not callable
Error executing string `def initializeArcFM():
  • Dec 15, 2015 8:23 AM UTC
The error message indicates that either of the 'app' or 'runtime' objects failed to initialize.
Maybe try manually typing the commands into idle or something to see exactly what the error is
  • Dec 17, 2015 2:00 PM UTC
Can you explain to us, why the definition is in Startup and the call is just in Shutdown ? I don't think there is a communication between the startup and shutdown script.
  • Dec 17, 2015 2:18 PM UTC
I think all Python code inside a single running workspace is executed inside the same instance of the Python interpreter. That is why it is possible to define global objects in e.g. a PythonCaller and then reference them in the shutdown script. So technically I would assume the above to work, although I agree that it is a bit weird ;-)
A somewhat interesting exception is if you use Python-based transformers in the workspace (notably the StatisticsCalculator), which re-initalizes the Python interpreter on the first feature, making you lose everything that was defined in before that point.
  • Dec 18, 2015 12:47 PM UTC
You need to have a confirmation from Safe from this point: "all Python code inside a single running workspace is executed inside the same instance of the Python interpreter"
  • Dec 18, 2015 1:11 PM UTC
I agree, that would be ideal. However, it is pretty easy to test for using global variables. So far, it seems to hold true, and I take advantage of it quite often.
erik_jan
  • Dec 18, 2015 9:34 PM UTC
Hi All,
Thanks again.
Hi All,
Thanks again.
Hi Erik_jan, can I ask if you install pythonwin for your script to run?
