Python executable and site-package folder in various versions (e.g. 2022.2.6) ?
  • Oct 2, 2024 12:13 PM UTC
  • 178 views
lifalin2016
Forum|alt.badge.img+42
Hi.
Is there an authoritative list somewhere of which versions of FME uses which versions of Python ?
So far I have: 2020=3.7, 2021=3.8, 2022=3.9+3.10, 2023=3.11, 2024=3.12
I’m assuming that the Python executable is located in [FME_ROOT]\fmepython###\python3.exe (or the dll’s). Is this correct ?
And where is this executable’s site-packages folder located ?
Is it at [FME_ROOT]\python ? Or [FME_ROOT]\python\python312 ? Or somewhere entirely different ?
And is this location the same in an FME Engine for Server/Flow ?
I’m contemplating adding a special Python package for use in both desktop and server.
Cheers.
lifalin2016
  • Oct 4, 2024 12:24 PM UTC
It seems that [FME ROOT]\python\python### is the folder to place your custom modules into. Not in a site-packages subfolder, but directly in the folder itself.
And FME Server/Flow engines behave the same way.
I’m closing this topic.
luke.hicks
Forum|alt.badge.img+11
  • Oct 7, 2024 3:35 PM UTC
Hi @lifalin2016 ,
You can find which versions of Python are included with each build of FME Form and FME Flow by checking our Build Numbers for FME Versions page.
Your executable’s site-packages folder will be located at “<FMEInstallDir>\python\python<version>”. On FME Server, you can upload your files from the aforementioned directory to Resources>Engine>Plugins>Python>python<version>. You can find out more about Using Python with FME Flow here.
Cheers,
  • Luke H.
