I would like to have a parameter that is set from data that is sent to it from a webpage. When you create a parameter the prompt asks for a prompt. I am not sure what to set here. I need to have the pararmenter look at the data sent from the web page and set that so a creator can use it to set parameters. I am fairly new to FME also so any help would be great thanks.
