Published parameter based on another published minus 1
  • Mar 15, 2018 8:58 AM UTC
  • 68 views
Hi all
Im trying to super optimize a workbench I have that reads a bunch of data from a mssql database, the workbench has 2 published parameters that i use to set years in the "Where" clauses of readers. both parameters have years as values, the parameters are
$(year)
$(year_minus_1)
Is there any way to base the parameter $(year_minus_1) on $(year) and then minus one year. if the value of $(year) is 2017 the value of $(year_minus_1) should be 2016.
Is it possible to do this so you only have to input 1 parameter?
I know its not a big thing but it would make the running of the workspace every year easier for other people running it.
lau
Forum|alt.badge.img+3
  • Mar 15, 2018 9:52 AM UTC
You can use a python script parameter (year_minus_1) and set it like this:
previousYear = int(FME_MacroValues['year'])-1
return previousYear
  • Mar 15, 2018 1:18 PM UTC
return previousYear
Awesome, that did just the trick :)
