Publish a daily generated file to another folder once per month
  • June 6, 2024
  • 34 views
purplecinn
Participant
Hi, I am trying to publish a file to a certain folder once per month by using FME workbench.
Currently, the file is generated daily with the filename format of YYYYMMDD.  And in the destination folder, there is a single file for each month, e.g. 20240101, 20240203, 20240302, etc.
For example, if I run the workbench and generate the file on 20240601, the file should be published to the destination folder as there was no existing files in the folder with YYYYMM=202406.
However, when I run the workbench again on 20240602, the file should not be published to the destination folder, as there is already one for 202406.
Any help would be appreciated.
liamfez
Forum|alt.badge.img+35
  • June 6, 2024
You could have a Directory and File Path Reader read in the main folder with all the monthly folders and then compare the current data’s YYYYMM value to check for a match. If there is no match it proceeds, if there is then you can use a Terminator to terminate translation.
