Problem translating shape files in batch
  • Apr 6, 2016 8:46 AM UTC
  • 84 views
femo
I want to run a script several times. Every time the input data changes.
I thought, this could nicely be done by triggering FME by means of a commandline batch.
However, when i start the batch, only the dataset which is connected within the workbench is used.
It seems, as if the sourcedatasets from the command lines are ignored. The parameters I have copied from the first lines in the log window. I have simplified the attached workbench to the key issue of importing and writing a shape file. Also attached you find the batch file and some data.
Any ideas?
Best answer by david_r
Hi
When creating the reader, remember to specify using a single merged feature type:
David
  • Apr 6, 2016 8:58 AM UTC
Hi
David
  • Apr 6, 2016 9:03 AM UTC
Hi @femo, you may have to check Merge Feature Type option in the reader feature type.
  • Apr 6, 2016 9:11 AM UTC
oops, my answer duplicated with @david_r's suggestion. Both are the same.
femo
  • Apr 6, 2016 10:17 AM UTC
Hi Takashi and David_r,
that was the issue! Thank you a lot for the quick support!
