Problem Establishing Connection from Workbench to Server
  • June 30, 2016
  • 22 views
The problem is after opening a new workbench, It takes long time to establish connection to fme server. It hangs at 'Waiting'.
Then I try to use CurrPorts to see what is going on in the background.
I discovered that 5 connection requests were generated after opening a new workbench.
And workbench seems to make iterative connections to
54.192.131.X | server-54-192-131-X.ams50.r.cloudfront.net | 443
Workbench refuse to send connection request to fme server until the above connection is closed.
Any Ideas?
/Xin
davideagle
Forum|alt.badge.img+21
  • August 8, 2016
That one sounds like its worthy of you opening a support case direct with Safe I'm afraid, via https://support.safe.com/knowledgeSubmitCase.
