Populate with attribute value from another table
  • Mar 24, 2016 1:32 PM UTC
  • 518 views
I have selected certain features from a table based on a certain attribute value. From another table I have done a selection as well to get only one specific feature. Now I would like to add the attributes and their value of the feature of the second table to all the selected features of the first table. I can not use the Featuremerger because the features of both tables don't have any attributes in common.
  • Mar 24, 2016 1:46 PM UTC
Hi
Do you want to join the attributes regardless? You can just set both the supplier and the requestor criteria to e.g. "1", like this:
That way the all the requestors will receive the attributes from the supplier.
David
  • Mar 24, 2016 1:57 PM UTC
Great, thanks. Is the Featuremerger the best transformer to use in this case?
  • Mar 24, 2016 2:25 PM UTC
There are several other options, but the FeatureMerger is what I'd start off with, as I find it is the easist to configure and it "just works".
gio
Forum|alt.badge.img+15
  • Mar 24, 2016 3:43 PM UTC
and set proces duplicates, list and explode
