Populate User Parameters automatically
  • Dec 17, 2024 8:19 PM UTC
  • 169 views
nmily89
Forum|alt.badge.img+4
Hello everyone,
I have some published user parameters, and the choices will be retrieved from the database. Is there any way to have the user parameters to be updated automatically once the workspace opened?
Thank you everyone.
Best answer by hkingsbury
Unfortunately user parameter choices are hard coded into the workspace and are not able to be updated dynamically based on data.
hkingsbury
Forum|alt.badge.img+73
  • Dec 17, 2024 9:36 PM UTC
geomancer
Forum|alt.badge.img+71
  • Dec 18, 2024 7:58 AM UTC
You can read the data from the database in one workspace, and pass the values to the user data of a second workspace using a WorkspaceRunner (in FME Form) or a FMEFlowJobSubmitter (in FME Flow).
nmily89
  • Dec 23, 2024 5:12 PM UTC
Thanks for your response. I don’t think It will work in my case because the end user needs to select choices before running the main workspace.
