points isolés fme | Isolate Points in FME
  • Oct 2, 2024 2:06 PM UTC
  • 20 replies
  • 226 views
kanteyemaodo
Forum|alt.badge.img+5
j’ai deux couches
Une couche de points (ponctuel) et couche de lignes (linéaires).
je veux vérifier les points isolés ou non connectés de ma couche ligne.
solution svp.
en pièce jointe les supports (points) à vérifier qui ne sont pas connectés aux lignes (tronçon).
I have two layers
A layer of points (point) and layer of lines (linear).
I want to check isolated or unconnected points of my line layer.
solution please.
attached the supports (points) to check which are not connected to the lines (section).
Best answer by geomancer
From the documentation:
Output Port ‘Line’: Line features which have been split at the location closest to matching points, with attributes added according to transformer parameter configuration.
geomancer
Forum|alt.badge.img+71
  • Oct 2, 2024 2:43 PM UTC
There are several ways to identify the points that do not touch the lines.
If the points are exactly on the vertices of the lines, use a SpatialFilter. If they are not, use a PointOnLineOverlayer with a small tolerance.
kanteyemaodo
  • Oct 2, 2024 3:05 PM UTC
les Chaque point représente un support de foyer lumineux du réseau d’éclairage public.
les points sont au niveau des intersections.
kanteyemaodo
  • Oct 2, 2024 3:14 PM UTC
geomancer
  • Oct 2, 2024 3:17 PM UTC
Probably the 'Passed’ port of the SpatialFilter contains the points that are exactly on the vertices of the lines, and the 'Failed’ port contains the points that are not on the vertices of the lines.
But of course that depends on the settings in the SpatialFilter.
kanteyemaodo
  • Oct 3, 2024 6:52 AM UTC
voici le paramétrage du transformer.
c’est correcte ?
geomancer
  • Oct 3, 2024 7:15 AM UTC
I'm sorry, but I can't decide that for you.
The parameters are right when the results match your expectations.
Have you looked at the results of the SpatialFilter? Are the points that exit from the 'Failed’ port unconnected to the lines, and do the points that exit from the 'Passed’ port match the lines?
kanteyemaodo
  • Oct 3, 2024 8:49 AM UTC
NON
geomancer
  • Oct 3, 2024 8:56 AM UTC
Can you provide some sample data? That will make it a lot easier to help you.
kanteyemaodo
  • Oct 3, 2024 9:47 AM UTC
les données sont en 3948
geomancer
  • Oct 3, 2024 9:55 AM UTC
Thank you, I will take a look.
kanteyemaodo
  • Oct 3, 2024 10:08 AM UTC
merci
geomancer
  • Oct 3, 2024 10:36 AM UTC
It turns out the points often do not exactly coincide with the vertices of the lines. So SpatialFilter may not be the best choice here.
Yesterday I also mentioned the PointOnLineOverlayer. When I use that transformer with parameter Point Tolerance set to 0.1, I get 13 points that are not within that distance of a line.
You will have to experiment with this parameter to get the value that works best for your data and your needs.
I could not reproduce the error you got on the PointOnLineOverlayer, so I have no idea why that error was triggered.
Note that PointOnLineOverlayer tests whether a point is within a certain distance of a line, not whether it is within a certain distance of a vertex of that line.
kanteyemaodo
  • Oct 3, 2024 10:54 AM UTC
Thank you very much. I'll test again and I'll get back to you later.
Thank you.
kanteyemaodo
  • Oct 3, 2024 12:52 PM UTC
ok c’est bon.
pourquoi les lignes sortent dans output (1087) ?
geomancer
  • Oct 3, 2024 12:57 PM UTC
kanteyemaodo
  • Oct 3, 2024 1:16 PM UTC
merci.
geomancer
  • Oct 3, 2024 2:26 PM UTC
You're welcome!
Providing the sample data really helped.
kanteyemaodo
  • Oct 11, 2024 8:54 AM UTC
fichier cadastre à fissionner dans FME
hello ! j’ai 3 couches shapefile
-bâtiments
-parcelles
-limites communes
je veux les fusionner pour avoir un seul fichier dxf (Microstation).
geomancer
  • Oct 11, 2024 9:18 AM UTC
Bonjour!
Can you make a new call for this? Then somebody else may be able to help you.
kanteyemaodo
  • Oct 11, 2024 9:30 AM UTC
