Performing loop queries using FME
  • May 30, 2025 3:44 PM UTC
  • 6 replies
  • 258 views
gennine
Forum|alt.badge.img+4
Hello,
I would like to perform queries on a branched electrical network composed of sections interconnected according to the current direction. However, the "TopologyBuilder" and "NetworkTopologyCalculator" transformers facilitate this task, but have limitations regarding the manipulation of downstream sections.
For example, I have the entity "i" and I want to collect and query the values ​​of the entity "i+1" (by analogy with the "for" loop in Python), then "i+2", etc.
Do I have to use Python development, or are there other, simpler solutions?
Thank you in advance for your valuable assistance.
Best answer by arenscott
I wonder if the ‘adjacent feature’ functionality in FME would be able to help here:
https://fme.safe.com/blog/2017/08/adjacentfeatureattributes-evangelist166/
Forum|alt.badge.img+54
  • May 30, 2025 3:57 PM UTC
Do you need to loop? i.e. is the result of the first query required for the second query or do you just want to make multiple queries?
gennine
  • May 30, 2025 5:50 PM UTC
Thank you @ebygomm. I would like clarification on the process of collecting values ​​from the second connected segment (sometimes there is more than one connected segment) and performing multiple queries. Once completed, I select the next segment, and so on.
  • Jun 2, 2025 7:39 AM UTC
Whilst it’s possible to do some looping in FME, I’d nearly always choose to do looping within a python caller if it is required.
In my experience, looping in FME is often more complicated than a python solution
gennine
  • Jun 2, 2025 9:26 AM UTC
Just one last point, I would like to know what type of python PythonCaller uses (pyQgis, ArcPy, or FME's own library)?
Thank you in advance for your help.
arenscott
Forum|alt.badge.img+11
  • Jun 2, 2025 8:30 PM UTC
gennine
  • Jun 3, 2025 9:00 PM UTC
Many thanks @arenscott. I think this is an excellent way to solve this issue.
I also thank @ebygomm for his suggestion, but unfortunately I'm not very proficient with PythonCaller.
