Pass password, get plaintext
I use the readerprompt widget [1] and pass all parameters to my reader using RUNTIME_MACROS (as described in the link). One of the returned values is a password (GUI type: password [2]), like:
"RUNTIME_MACROS,...<comma>USERNAME<comma>bob<comma>PASSWORD<comma>fme_decrypt<openparen>MDowfCN8I3xcG3GQ<solidus>TeRRUJUZ5LDPtdvpscbh7Nj9gG<solidus>INBkAGA+fkaDrNbhZtfa3rmkUUrCxKWaAFwiYsKgWJNl<solidus>0mRpxUuP+IT2c+Qhh26JEZtUWAmpuoaQCdQ3ykKWm2zaoAM5MBCGaGEuYe+6AS07<solidus>nLNRJwqp1jdwP1FgVCbXRvZtWfKjEZlNJYQ+EicVc6cv2DxCYJyTljvXwF8mKxenML6FKJiHARQCO8OMJidKKZQJP1SeYIhqB0YrtGw4cGV2ZquQKifvRjB2Tl6wBAWDmeCg+R1jvft1tR17SISyTDv77K+mV80w2aaUSgybbF7coM0BrQPcpehfjlW+YxV73+9mPMFXKQeznZ22T8MJor57O44p8U2NQCw35HiFBs0oVP9VkkY0D<solidus>WzGRevseyX1pIEWJSQSFwkJVhiyXavMDz5E5SEYgTZHfVeGBXCDuIEEbfRRkPU5yD2nw2ZAVimDRD7UQhEEY6PosGqU17He4y35WEfAggQ40+EKuupOQSZRsKotTTqlYGHJtX49ymuKqfyZzOAUSUzDMcj8gfDgzOCcuhw2sK3fJaMsz9ZV9+y<solidus>Vf7hyk9rwq4f3aoyrwX7P<solidus>Hp65YhE5rOxzPLjSh1i2S9mZLDBE5c3czZRpJB4rJsC8kl4zQ96C63rTh4NziSj8cEBK+AJpcwnvdQwVUQ1UYJiXWKb5weIFYW4O5a4+xBilEYr8wu1Z6sc8CVeiToCUH+0q4TzMs+OpBj1jaPlqxZ7McVC6K62uafWtXgUCUudmT8ELma9MZhyYiO59w6FvDztQBokoFD2ZIxITBZonuWecxIXcQXzjv+sSCpuV2TaqJBdRm4wmo07qgKwOtzG3b<solidus>GvDfQTfePDtsd0GxWk85fxFcdxZlVpv32D0Mi2FTeHu1MOTgbj7PrqTwvWBUXrNNO<closeparen><comma>..."
Of course, I need the plaintext. How can I get the plaintext?
Thanks
ben
[1] http://docs.safe.com/fme/html/FME_GuiType/doc_pages/readerprompt.txt
[2] http://docs.safe.com/fme/html/FME_GuiType/doc_pages/password.txt
  • October 7, 2015
Hi
I searched around a bit and I couldn't find anything either. I suspect that Safe does not want to expose the "fme_decrypt" function since it would go against the very idea of encrypting the passwords in the first place.
David
  • October 7, 2015
Thanks for answering.
Can I set the password as a publish parameter? Then, my reader could read it from there.
I heard about TCL and scripted parameters, but I am not sure if that can help me in this scenario.
  • October 8, 2015
Sure, you can define a published parameter of type text that you link to the database password parameter.
You probably do not need to use any TCL or scripted parameters for this.
David
  • October 9, 2016
Security Issue (for me)
If you want to decrypt the password, it's very simple.
  • Create a private parameter with your password
  • AttributeSetter: create a new attribute and set the value with your private parameter
  • Logger
Your password is decrypted
  • October 9, 2016
  • Logger
FME Desktop 2016
