Parsing Filename(multiple) parameters
  • Sep 22, 2017 7:34 PM UTC
  • 61 views
jdh
Forum|alt.badge.img+41
What method do use to parse the Filename (multiple) parameter in python?
I currently use
source = FME_MacroValues['Param1']
if source.startswith('"'):
from shlex import split
fileList = split(source[1:-1])
else:
fileList=[source]
but it feels clunky.
The assumption is that if it's a single file, it is not wrapped in quotes, but if it's multiple files it is:
""file1" "file2" "file3""
daveatsafe
Forum|alt.badge.img+24
  • Sep 22, 2017 8:23 PM UTC
Hi @jdh,
You could try:
filelist = shlex.split(shlex.split(source)[0])
  • Sep 22, 2017 10:46 PM UTC
The shlex.split method may not work as expected if a file path could contain a space, so I would use str.strip and str.split method simply. This works like the AttributeTrimmer and the AttributeSplitter.
filelist = source.strip('"').split('" "')
