Parsing attribute values
  • May 16, 2013 4:59 PM UTC
  • 209 views
I have a workspace that compares a PATH HIERARCHY data set attribute of video file names to a GeoMedia Feature data set attribute of sewer segment names and does a feature merger on the two datasets when there is a match.  Sewers are usually videod from upstream to downstream and the video files are named according to the direction in which the camera was travelling.  My workspace gets quite a few matches BUT...there are occasions where the videos are named from downstream to upstream which causes my feature merger to send that video name to the incomplete branch.  I would like to parse the video name attribute and use the result to create a new attribute that is the reverse.  So 'MH07-121 to MH07-122' would become 'MH07-122 to MH07-121' in the new attribute.   Could someone please suggest an approach that would accomplish this for me?   Thanks.
fmelizard
Forum|alt.badge.img+22
  • May 16, 2013 6:25 PM UTC
I would parse the attribute value with a regular expression = string searcher and reconcatenate the matching parts (string concatenator) to form the new value.
Hope this helps.
fmelizard
  • May 16, 2013 6:59 PM UTC
As always there are more than one way to do things in FME, so if you value is separated by ' to' you can use that as the delimeter value in the attribute splitter   and then reconcatenate the list values.
  • May 19, 2013 5:20 AM UTC
Yes, there should be some approaches.
I would use StringSearcher, Tester and StringReplacer.
Takashi
