parameter to deactivate other parameters
  • September 21, 2016
  • 17 views
zzupljanin
Forum|alt.badge.img+5
Hello FMEers,
i'd like to define one published parameter which will use one of others. For example, I need to create statistical data by roles (parameter ROLES) xor by users (parameter USERS). If I choose by user, I want the ROLES parameter to be deactivated. After that I can choose which user...
So, question: how can I achieve that.
itay
Forum|alt.badge.img+18
Hi @zzupljanin, dont think 'deactivated' is an option for a parameter, seems to me like you want to test if a parameter1 has a value then do this but if parameter 2 had a value do that....if this is the case a simple tester or testfilter should do the job.
Hope this helps
From a user interaction point of view (GUI), that isn't possible.
But as Itay says, you can use your workspace logic to test for illegal combinations etc.
zzupljanin
Yes, that's what I needed. I understand Tester logic, but the question is with GUI... now I know, thank you.
mark2atsafe
Forum|alt.badge.img+59
Yes, unfortunately this isn't possible. It's filed as PR#36909 and I will let you know here if and when it is implemented.
The other action you can take is to upvote this idea: https://knowledge.safe.com/content/idea/25358/richer-user-parameters-prompt-ui.html
