Parallel offset with no curve stroking?
  • Sep 9, 2014 5:38 PM UTC
  • 10 replies
  • 128 views
I’m trying to emulate a CAD command for offset.  Essentially I want a parallel offset of a line with no curve stroking on the outside angle.  Similar to bufferer but with the ability to make the stroking density a value of 0.  Any easy way to do that?
gio
Forum|alt.badge.img+15
  • Sep 10, 2014 4:01 PM UTC
Can't u the use the bufferer and then coerce it to a line?
gio
  • Sep 10, 2014 4:02 PM UTC
btw, if u ofset it too far, it will distort the outer boundary and u won't get a good offsetline...
Thanks Gio,
I tried what you showed, and that works to connect the offset line nicely, however, on the outside offset, it is still a stroked curve.  I'm trying to achieve something like the red line below but on buffer, the minimum stroke density is 1 instead of 0.
gio
  • Sep 12, 2014 9:27 AM UTC
Hi Alan,
Here is one that does that.
It is build for a open ended polyline.
If u do this to closed u need add a loopfilter in the customtransformer prior to testfilter and send the loops to extender2.
(i'm trying now to build a lineintersector transformer (vector math, like the offset-affiner) so i can do away with the extending..)
Haves fun.
gio
  • Sep 12, 2014 2:23 PM UTC
HI,
With a little fiddling i made one that handles closed and open polylines, even when they intersect.
It wont work for curves yet; comming soon!
gio
  • Sep 12, 2014 2:31 PM UTC
better picture red are offsets, other lines are original polylines. Buffer is just for visuals.
Wow.  Looks like that does what i am needing.  I will play around with that to try and get it to work in my application.
Thanks Gio
umapper1
Forum|alt.badge.img+5
  • Apr 6, 2020 6:09 AM UTC
@gio @alan_surveyor did you ever get a workspace/custom transformer completed to do this? I'm looking to do this in one of my workspaces and all these years later there's still no offset tool to do this!
gio
  • Apr 6, 2020 10:06 AM UTC
ZeroStrokeOffsetter_V3_cleaned.fmwt@umapper1
Here is the workspace i made.
I did update it to 2018 (and cleaned it a bit for you) and i not yield nice.
There is some English annotation there. Hope it helps.
Too big offset in relation to the object will of course not yield a desired output. (there is no in-built check for that)
Greets and stay healthy!
Gio
umapper1
  • Apr 6, 2020 9:44 PM UTC
Gio
Thanks very much @gio! It might help me in the interim. By the way, I've created an Idea on the forum to request a 3D parallel figure transformer to do what we're after if you'd like to upvote it?
https://knowledge.safe.com/content/idea/110729/parallel-figure-transformer.html
