Overwrite an attribute with another files attribute: Would you know how to set a conditional query so if file A's attribute X = file B's attribute X, it changes file A's attribute Y to the value found in file B's attribute Y?
  • May 4, 2017 6:11 PM UTC
  • 53 views
erik_jan
Forum|alt.badge.img+26
  • May 4, 2017 6:26 PM UTC
You should use the FetaureMerger to merge file A features to file B features based on the Join X values.
The on the Merged output (X = X) you can use a AttributeCreator to create file B's Y using the conditional value option (find in value under the arrow).
  • May 4, 2017 6:35 PM UTC
Fab, works like a charm!
thanks erik_jan
