oracle spatial reader unwanted schema attributes
  • Dec 20, 2019 12:36 AM UTC
  • 65 views
burgasser
Forum|alt.badge.img+5
Hi:
In FME Desktop 2019.1.3.1, when adding a table using the Oracle Spatial reader, I'm getting some unwanted attributes shown below (starting with fme_geomattr). I am not purposely exposing additional schema attributes. They just show up unwanted. Does anyone know how to avoid having these additional attributes exposed when adding feature types? Thanks!
@burgasser This definitely isn't expected. I couldn't reproduce your behaviour. Can you give us more detail about your configuration:
Oracle version ?
It would probably also help to see if there is something special about your Oracle table - perhaps if you could include the Oracle table create SQL statement it might give us a clue. Could you include the FME log file from when you add the reader to your workspace. Thanks.
burgasser
  • Dec 21, 2019 1:45 AM UTC
Oracle version ?
Oracle version is 12.1.0.2.0.
It doesn't seem to happen in 64 bit, only 32 bit.
It's not consistent - it does not happen always.
Sometimes, it will happen only once. If I delete the feature type, and re-import, the unwanted attributes are NOT there sometimes. Not only that, but if I close FME, re-open, and re-add, the unwanted attributes are NOT there.
There's nothing unusual about the tables. There are entries in the USER_SDO_GEOM_METADATA for the tables. There are spatial indices.
It's not terribly critical.
Thanks!
