Optimize translation of a large list of CAD files using FeatureReader and Writer/FeatureWriter
  • Feb 15, 2018 11:36 PM UTC
  • 6 replies
  • 100 views
lottegis
Hi there,
I have a translation between Microstation DGN files and AutoCAD DWG files where there can be as many as 6000 files at a time, but I'm encountering memory resource issues. I want to avoid splitting this translation into a child process with a WorkspaceRunner or JobSubmitter where it will process 1 file at a time.
  • I'm using FeatureReader-DGN and tried with FeatureWriter-DWG / DWG Writer.
  • FME_TEMP points to a 2 TB drive and the translation accumulated 350 GB of temp files like these before crashing with another TB free:
    FME_OBJC_MultiWriter_1518629821107_13172_1
    FME_OBJC_MultiWriter_1518629821107_13172_235
  • Virtual memory is set to automatic paging on the same drive
  • I have 16 GB RAM
  • DGN file sizes range from 13 KB to 29 MB
  • FME 2016.1.3.2 #16717 WIN64
FME seems to accumulate all the features from all the files before it writes out a single feature to a physical file. Is there a way to maybe (1) batch up the list files so that n-number-of-files are processed at a time, or (2) get the writers to output a full file before the reader reads the next file?
Attaching a sample workspace.
Thank you.
pratap
Forum|alt.badge.img+12
  • Feb 16, 2018 5:17 AM UTC
My approach is differnet than yours.
1st workspace: I will start with DGN reader (single merged feature type option) and I will use published parameter to pass the file name. I will make necessary modification to the features as required and write to DWG writer.
2nd workspace: I will start with excel reader to pass the parameters with workspace runner of above workspace.
This will make 1 dgn / execution and can get rid of memory issues even when dgn files contains more number of features
Hope this helps.
Pratap
lottegis
  • Feb 16, 2018 7:47 AM UTC
Hope this helps.
Pratap
With your method, have you had job failure 1000+ or 2000+ files into the translation on FME Server? I've had it happen for another translation and it is why I want to avoid WorkspaceRunner or JobSubmitter in this case.
pratap
  • Feb 16, 2018 7:51 AM UTC
You mean to say that we will get memory issues, if input is 1000+ files...
jneujens
  • Feb 16, 2018 10:17 AM UTC
As pratap already advised, I think you already mentioned your own solution. Try using a parent/child structure. It will always be a better way to process so many files/data.
lottegis
  • Feb 16, 2018 5:21 PM UTC
When there's 2000+ files, I'd get this error:
ERROR |Terminator_deliver_asc_xyz: Failed to
open FME feature store file `\\storage\05232112\FME\resources\logs\engine\current\jobs\9000\job_9253_0_log.ffs' for write -- ensure that the folder exists
My understanding is, this job_####_0_log.ffs
file gets overwritten again and again, based on how many times the child
workspace opens.
Did you have this behaviour?
pratap
  • Feb 17, 2018 4:33 AM UTC
workspace opens.
I have not tried in same translation i.e. dgn to dwg but I have tried to dgn to oracle db some time ago for 2000+ files. It didnt gave any error.
As far as I understand, FME wont overwrite the file as many times the child opens until we tell to FME to perform.
