OAuth2-Web Connection ceases functioning based on user account and machine
  • April 17, 2024
  • 54 views
geotinkerer
Forum|alt.badge.img+5
I have encountered a strange issue with FME web connections via OAuth2 which does not seem to be resolved yet.
On one of our company’s networks physical Windows 10 PC, there are three versions of FME Desktop / FME Flow installed in parallel (we need these to cater to our different customer’s needs). When I routinely tried to check and update an FME workspace, I ran into the problem that authentication with an OAuth 2 Web connection (via Microsoft 365 account) did not work anymore. At first, the web connection window took more than 40 (!) seconds to appear with the logos sometimes not even fully appearing. When I entered my credentials, it takes another 20 seconds and then gives me an error not to have found it. The credentials are tested and correct. There are no proxy connections.
Resetting FME Options has not worked, and neither has setting up the web connection completely from anew.
Tests on a different machine within the same network (but on my Windows user) could not replicate the problem, so I would assume there are some user specific config files that appear to be shot. I also tried to rename the “fme_connections.data” db in the user folder, to no avail.
to summarize, in short
-it happens with a particular user on a particular machine, but on all installed FME Desktop / FME Flow versions
-the same connection works with the same windows user on a different PC in the network
-the connection also works on the affected pc when a different windows user accesses it.
Is there any solution left apart from reinstalling all FME Versions on the affected machine?
evieatsafe
  • April 18, 2024
Hi @geotinkerer I have some additional questions to get started:
  • What version of FME are you using, and have you recently upgraded?
  • Does this happen with all of your web connections, or is this specific to MS?
  • Any other information you could provide as well.
geotinkerer
  • April 19, 2024
Hi @evieatsafe
  • I am using 2020.2, 2021.2 and 2023.2. No recent upgrades, and the same settings used to work well with the same versions before.
  • I don’t use any other Web Connections, so it’s hard to verify. MS connection works fine with other apps though.
  • In the meantime, I tried on a different PC within our network (with FME 2024.0). The problem does not occur there, so I guess it’s somewhat linked to my local FME config files or thereabouts. I also reckon that when multiple versions of FME Desktop/Form are installed in parallel, they all access the same configs for the same Windows user.
