No module named 'pyfme' error
  • Mar 13, 2019 8:39 PM UTC
  • 109 views
I have an older script that will no longer execute importing pyfme. Any suggestions as to why?
Log translation details below:
FME_END_PYTHON: evaluating python script from string...
Python Exception <ModuleNotFoundError>: No module named 'pyfme'
Error executing string `import pyfme
Shutdown Python Script details:
Best answer by geosander
That's old, yes :)
The pyfme lib no longer exists. Replace it for fme instead (and for PythonCaller scripts, you'll need fmeobjects).
Also replace pyfme.FME_MacroValues with fme.macroValues. Don't know if your code block above shows all usages of pyfme, but after the replacement, it should work for this part.
Sander
geosander
Forum|alt.badge.img+7
  • Mar 13, 2019 9:03 PM UTC
That's old, yes :)
Sander
  • Mar 13, 2019 9:38 PM UTC
That's old, yes :)
Sander
Thank you! I thought as much, but was having a hard time finding the replacement information you provided. Much appreciated Sander.
