Is it possible to steer this sequence order?
Navigation through the workbench
I have a FME workbench here and at certain points the output of transformers is connected to two other transformers. So the workbench get seperated in several branches. I wonder in which sequence order the transformers are activated. This is important, because in the several branches editing is done on the same objects.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
