Named Database Connection as publish parameter of a custom transformer
  • Sep 21, 2016 2:30 PM UTC
  • 6 replies
  • 100 views
Is it possible to define, inside a custom transformer, a published parameter corresponding to a named database connection ?
The idea is to develop a generic custom transformer that manage metadata tables. This custom transformer must be able to work on differents database/schema.
Thanks,
Thibaut.
Best answer by courtney_m
@thibaut_gheysen It is possible to do this for a named connection for some formats. For example, if I take the same SQL_Executor from my ELocationPopulater transformer, and set the format to "Oracle Spatial Object", leave the Dataset blank, and click on Parameters, I can create a named connection parameter for the Dataset value. See the image below.
courtney_m
Forum|alt.badge.img+23
  • Sep 21, 2016 4:38 PM UTC
Thibaut,
Yes, that is possible, and you can do it using embedded connections. For example, I created a custom transformer called the ELocationPopulater, which needs to run a SQL query on an Oracle table. So, within the custom transformer, in the SQLExecutor parameters, I chose to "Embed Connection Parameters" - then, for the Service Name, Username, and Password, I created user parameters (see screenshot below).
When I use the custom transformer in a workspace, I am prompted to enter the correct values for the connection parameters:
Hopefully this helps!
-Courtney
Thibaut,
-Courtney
@courtney_m Thanks for the answer but I would like to use named connection instead of embedded connection (sorry was unclear on my question, I edited it accordingly).
I don't want to include database connection parameters in the workspace. The main reason is that the workspaces will be publish to multiples FME server, each one with a separate database. The idea is to create the same named connection on each FME server but with different parameters. Like that, according to witch server the workspace is published, the connection will be done on the right database without any modification of the workspace.
courtney_m
  • Sep 21, 2016 8:02 PM UTC
courtney_m
@courtney_m Thank you, it works. I was trying to create the published parameter from the parameters list (navigator) and I completely forgot about the possibility you mentionned in your answer.
