Multiply the attributes with value
  • May 24, 2016 4:08 PM UTC
  • 344 views
boubcher
Forum|alt.badge.img+11
How could we apply a Multiplier to the attributes value , but the multiplayer value is a variable ex : parcels area * factor and factor value is read from DB of excel cell : )
Best answer by takashi
Hi @boubcher, since the ExpressionEvaluator evaluates the expression for each feature, all the attributes which are used in the expression have to be contained by a single feature. In this case, every "Brida" feature should have the "factor" attribute.
Consider merging the "factor" to the "Brida" features before inputting to the transformer. The FeatureMerger or the Joiner would help you to do that.
  • May 24, 2016 4:19 PM UTC
Hi
Have you looked at the ExpressionEvaluator transformer?
David
boubcher
  • May 24, 2016 4:40 PM UTC
yes but it didnt work
check the transformer esrishape-xlsxr2pdf2d.fmwt
  • May 25, 2016 6:49 AM UTC
boubcher
  • May 31, 2016 5:37 PM UTC
Thank , woked
