merge surfaces
  • Mar 24, 2014 11:45 AM UTC
  • 7 replies
  • 336 views
Hi there,
Simple question really (I hope), is it possible to merge two surfaces by a common id?  I have multiple surfaces and only want 1 output, they have same id number but I can't seem to find any method of combining them into 1 feature.  I am initially using SurfaceOnSurfaceOverlayer to remove overlapping features, but then I end up with lots of surfaces, I want to then join them back together, but neither FeatureMerger, Merger or MeshMerger work.  Any suggestions?
Dan
Best answer by gio
Hi Gnr,  (are u from Qwghlm?)
You're right there is none, thats what i called mine.
But i got the idea from
http://fmepedia.safe.com/articles/How_To/How-to-clip-TIN-Surfaces
  • Mar 24, 2014 12:37 PM UTC
try with the Dissolver, setting a Group By on the common ID.
David
Hi David,
Unfortunately Disoolver (in 2013 anyway) only accepts 2D objects, so all surfaces are rejected.
  • Mar 24, 2014 12:53 PM UTC
Ah, sorry, I didn't quite see the surface bit.
Could the Aggregator be an option? Also with the Group By on the common ID.
David
gio
Forum|alt.badge.img+15
  • Mar 24, 2014 1:04 PM UTC
U need to decompose surfaces to triangles. Or if u are using surfacebuilder, do operations on the triangle outputs.
Triangles u can clip etc.
When done rebuild them to surface: facereplacer, aggregator and triangulator.
Look at a customtransformer in the store called Surfaceclipper. If u study it, you should be able to grasp the concept.
Gio
David,  I am currently using Aggregator to 'merge' the surfaces but all this is doing is creating a multi-surface rather than one continuous surface, still at least i reduces the volume of features for later.
Gio, I am afraid I can't see any SurfaceClipper in the FME Store, is this something that is only available in 2014?
gio
  • Mar 24, 2014 3:13 PM UTC
Hi Gio, thanks for that advice, that seems to have fixed the issue I was having!
