Merge Feature Types in CSV Reader
  • August 6, 2014
  • 22 views
I have a problem where I am trying to load a specifically named .csv file into FME. Basic right!?!? The problem is that the dataset I am loading is broken up in subfolders.
For example, I am opening “Folder A” with a hierarchy of “Subfolder A”, “Subfolder B”, “Subfolder C”, and so on. Within each subfolder is CSV file named “example.csv”.
I need to batch grab “example.csv” out of each subfolder. I considered using “Merge Feature Type” option but I’m a little rusty on how to structure my *\\**.csv setup.
I hope I’ve explained this well enough and would appreciate any direction on how to merge the CSV files (of a specific name) as a reader in the subfolders.
*Note, in the meantime, I manually added the 100+ files as a stopgap but it’s not an elegant or sustainable solution.
Thanks,
Matt
Best answer by takashi
Hi Matt,
You can use the Advanced Browser when setting the source dataset.
Add root Directory and check Subdirectories column. Then the reader will search all files in specified directory and its subdirectories recursively. And you can also edit File/Filter column to read files having specific file name.
Takashi
  • August 6, 2014
Hi Matt,
Takashi
