MapInfo dynamic schema attribut type
  • Oct 4, 2017 6:45 PM UTC
  • 69 views
francis_m
Forum|alt.badge.img+9
Hi
I have a workbench that goes like this :
Using FME Desktop 2014 (build 14339)
I'm using a FeatureReader to extract data (from SDE).
I'm using a FeatureReader to extract SCHEMA (attribute name and type) from the data extracted from SDE).
The schema is extracted because I need to change an attribute type before writing it to MapInfo (an SDE date attribute is formatted as fme_datetime and for MapInfo I need it to be fme_date).
I'm using python to change this and it works perfect.
Then I merge the extracted schema to every feature with the FeatureMerger and then output the data in Mapinfo.
The real problem is that I now need to change an SDE float attribut to a mapinfo decimal type (fme_decimal(10,5)).
FROM SDE : fme_data_type = fme_real64 and native_data_type = double
TO MAPINFO : the type is FLOAT
I try to change the fme_data_type and native_data_type to double (fme_decimal(10,5)).
In the workbench it's ok, but the mapinfo output is still FLOAT.
Any Idea?
Thanks!
Francis
Are you setting the fme_format_short_name ? This triggers FME to use the native data types instead of the fme data types see this article : section Using Format Specific Data Types. Set this to the format name for the Mapinfo writer you are using (MITAB or MAPINFO). I don't think you can mix and match using native data type vs fme data type, so if you choose to use native_data_type then you'll have to assign all your data types with that
francis_m
  • Oct 6, 2017 5:14 PM UTC
Thanks for the info. I'v already try with the fme_format_short_name. That didn't work.
I can change the format to "date" or "char" but not to decimal...
I've attached a little test workspace that seems to work OK in 2014. dynamicwriternativedatatype2014.fmw If you inspect the resulting .tab file in a text editor, it looks like the attribute data types are set correctly.
!table
!version 300
!charset WindowsLatin1Definition Table
Type NATIVE Charset "WindowsLatin1"
Fields 2
attr1 Char (10) ;
attr2 Decimal (10, 2) ;
This is a little easier to configure in newer versions of FME. If this doesn't work for you then perhaps send an example workspace and data to support@safe.com
francis_m
  • Oct 10, 2017 4:45 PM UTC
!table
!version 300
Fields 2
attr1 Char (10) ;
Thanks Mark for the try...
As I said, I can format the output attribut to char or date but not to decimal.
The datasource is SDE (in a SQL database).
Maybe It works when the SchemaSource is Mapinfo and the output is Mapinfo too.
I can change the attribut name too...
The source attribut in FME is 64 bit Real. In SDE the format attribut is Double.
I put a static schema for that particular table to avoid the problem.
Hope in a newer version it's ok!
Thanks!
Francis
