Making all non-numeric values null
  • May 16, 2018 7:52 PM UTC
  • 231 views
I am taking data from a shapefile and mashing it with a CSV, and the attribute I am having issue with has null, numbers and non-numeric characters/alphabetic values (from the input).
The target field in my output is an integer type (uint). I would like to make Null all attributes of that field that are non-numeric (some are purely alphabetic; others have characters like in a date format).
I was hoping to use an AttributeManager that I was already utilizing to perform this operation, but I don't know how (or what other transformer would be best).
Best answer by erik_jan
I would use the AttributeValidator to check what records have a non integer value and then the AttributeSetter (will be the AttributeCreator) to set that value to Null.
erik_jan
Forum|alt.badge.img+26
  • May 16, 2018 8:06 PM UTC
  • May 16, 2018 10:48 PM UTC
Yes, the AttributeValidator is a possible way. Alternetively, you can also use conditional value setting in the AttributeManager or the AttributeCreator. e.g.
If attr Type Is Integer Then <No Action> Else <null>
However, with those methods, I'm afraid that the workspace or parameters setting could become too cluttered if there were multiple target attributes. So I would use the NullAttributeMapper to make the workspace concise. [Updated]
  • May 17, 2018 1:22 AM UTC
Sorry, the regular expression was wrong. I've corrected the screenshot above.
