make contour polygon from points
  • May 29, 2016
  • 39 views
Hi, I tried to generate contour polygons from a point shapefile, here are the steps:
1. use 3DForcer to assign one attribute from the shapefile as Z value to make the point 3D;
2. use ContourGenerator (attribute LDEN has values in range (-20, 120), I have set the Interval to 5)to get contour LINES, i only use points as input, no breakline is provided;
3. Option 1: then use HullAccumulator -> GeometryCoercer to generate the boundary . After this, use Aggregtor to combine the contourlines and the boundary line, then the AreaBuilder to create the contour polygon, this options looks fine; Option 2: after step 2, directly use AreaBuilder to create the polygon, then I found the contour polygons are overlapped. For instance, contour 55 contains the contour polygon 60, 65 and higher.
Question 1: why is option 2 generate polygon like this? Why option 1 did the good job?
4. followed by option 1 in step 3, those polygons contains no values. So I use OffsetCurveGenerate ->CoordinateExtractor -> VertexCreator to generate points on both sides of each contour line to store the contour value. With overlay operation and statistics, each polygon get the min-lden and max-lden
My question 2 is: I noticed that the outmost polygon has a min-lden -20 and max-lden 55, looks like the inbetween polygons are all dissolved. Why is this happened?
Thanks for helping!
(I have uploaded the script and also the screenshot of the script)
todd_davis
Forum|alt.badge.img+22
  • May 29, 2016
Q1: For the Areabuilder, you are using a group-by right? So then it like throwing in a tester and sending each value to a seperate area builder. e.g. when you pass contour 55, it is not doing any checks for other values, its just using 55 to build a polygon
But just use the "DonutBuilder" with no group by after it and you will get what you want.
