Hi @lalandexavier, a possible approach is to create copies of the line for each pair of Start/End points and snip off the copied line by measures of the Start/End points. The idea is simple but the implementation could be a long story.
Gray: Original Line, Blue: Step 1 (moved to +Y direction), Red: Step 2
Dear @takashi, this is a perfect answer, thank you very much !
I saw, since this post, I identify few particular cases, for example same vertex for different points or linear not in the same direction explication-probleme-copie-copie.png.
In this case, I've a proble with the NeighborFinder because point doesn't match. If I use the Unmatchedcandidate, the MeasureExtractor doesn't work. finally if I work without the point unmatched, I don't have all my linears.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
