Looping url nextlink does not stop
  • Sep 6, 2018 4:15 PM UTC
  • 103 views
I have created a workbench that loops through an odata/json url using nextlink. I then placed a tester to stop running after the url returns no value. My problem is that this starts over after it runs the full data-set and repeats never stopping. A 700 feature table ran over the weekend had 70,000 and still counting.
jdh
Forum|alt.badge.img+41
  • Sep 6, 2018 4:47 PM UTC
Is the entire dataset repeated, or is it the last page that repeats endlessly?
Do you clear the nextlink at the end of the loop?
If the @odata:nextLink is not present, it won't overide the existing attribute from the previous iteration.
Thank you for the feedback. Looks like my issue was in the Published parameters. I create list of choices to append to the core url to select specific tables. I then use metadata to define the columns. This parameter needed to be passed to the looper. I found that i have hard coded the url in the looper http caller so when i changed tables on the workbench it was looping what actually was the largest table with millions of rows. My bad :)
