Loading CSV codes into TestFilter
eric_armitage
Forum|alt.badge.img+10
I have a list of codes (over 100) in a CSV and want to use a test for each code in a TestFilter. Is there a way to load them all at the same time rather than cutting and pasting individually?
Forum|alt.badge.img+39
  • May 12, 2022
Do you need to use the TestFilter? If it's as simple as testing an attribute for a code, you could use the AttributeFilter, this will allow you to import the codes from the csv
eric_armitage
  • May 12, 2022
Thanks but some of the codes are not an exact match so i need to also use operators like "Begins with" or "Contains regex". I've just had a quick look and I don't see any option to do that with the AttributeFilter
  • May 12, 2022
I'd probably still try and use the attribute filter, anything to avoid having to write 100 test statements! So find some method of adding the code as it's own attribute to the data, and then use the attributefilter on that. e.g. you could use an inlinequerier to join the code to the attribute that contains the code, then use the code for your filter.
