Lines to Points?
  • August 12, 2024
  • 555 views
vxn43
Forum|alt.badge.img+18
What is the best way to convert Lines to Points? I would like the points that are created to fall in the middle of the line and include all non-geometry attributes of each line.
I am hoping there a LinetoPoint Transformer out there somewhere.
Best answer by liamfez
You could try the Snipper. With the Mode set to Percentage, and then 50 for both the starting and ending location values.
liamfez
Forum|alt.badge.img+44
  • August 13, 2024
