LineDivider FME 2018
  • February 7, 2019
  • 34 views
I use a FME Server 2016 to run different workbenches. For the update on FME Server 2018 I have to upgrade these workbenches, too. In one workbench I use the custom transformer LineDivider from Takashi Iijima.
After the upgrade I have the problem, that the output of the upgrades workbench is less than the output of the old workbench.
old output
new output
Especially the PythonCaller has an other output. But the old and the new workbench should have the same size.
Has somebody an idea which parts of the PythonCaller has changed?
Thanks and best regards
Forum|alt.badge.img+62
I'm sure @takashi knows best what has changed (and I suspect that the change may have been made due to some issues I was running in to).
What you could do is use a ChangeDetector to see what the differences between the old and the new results are.
  • February 7, 2019
Yes I modified the Python script in 2017 in order to resolve @redgeographic's issues.
Could you please check if the History of the LineDivider in the new workspace is different from the old one?
Also, check if the parameters configuration is exactly same among the two workspaces.
  • February 8, 2019
thank you for your quick response.
The configuration of the transformers is the same in both workbenches. I upgrade the transformers by rightclicking on the every single transformer in the list "upgradeable transformers". There I can see that the configuration is the same for the old and the new transformer.
I check the history of the LineDivider. I´m sorry but I don´t know what I have to do with that information ^^
old LineDivider
new LineDivider
  • February 8, 2019
old LineDivider
new LineDivider
The History is here.
