.jpg .jgw with different coordinate system to Geotiff
  • April 12, 2024
  • 258 views
chaitanyamalla
Hallo FME community, I am new to this FME software and got a task.
I have 100 city folders with single .jpg and .jgw file inside each folders. .jgw has x and y coordinates of a reference system. Can anyone tell me workflow with necessary transformers to select each jpg with their .jgw and create their own destination folder and save the Geotiffs in individual folders.
jkr_wrk
Forum|alt.badge.img+36
  • April 16, 2024
I think you want to:
Creator → FeatureReader(Directory and Filepath) → FeatureReader(.jpg) → FeatureWriter(.tif)
The first featureReader reads all the files in all the (sub)folders. You then send all the jpg files (path_windows) to the second FeatureReader to read all the jpg files. I think FME recognizes the jpw (world file) and puts them in the right coordinate. Then you use a FeatureWriter to write Geotiff. Here you can do all sorts of things like writing to c:\project\@Value(path_rootname)\@Value(path_filename) to write to subfolders.
chaitanyamalla
unfortunately jpgs were not put correctly in coordinates by reading jgws by FME.
I have read JPGs and JGWs seperately and took the x and y values from JGW and assigned coordinate system to new raster from JPG according to X Y values manually.
jkr_wrk
  • June 20, 2024
If you set a coordinatesystem in the FeatureReader? Or use the coordinatesystemsetter transformer?
chaitanyamalla
I have added CRS with the coordinatesystemsetter.
