iterating/looping a workspace using attribute values
helentait
I have a fairly large workbench that uses quite a bit of processing muscle, so I am limiting which features are processed at one time by using an attribute value (a line reference) exposed as a published parameter i.e each time I run the workspace, I enter a new line reference to be processed. I have about 1500 different line references to process. How can I automate this so that I don't have to manually enter each new line reference?
Best answer by 1spatialmary
@helentair - take a look at the WorkspaceRunner transformer, this will run your process as a second workspace based on the values you pass from the first one (your attribute values). Another option is to use a .bat file with the command line text to run the workspace for each parameter value replicated for each changing value of your attribute.
  • December 7, 2017
You could consider using a parent workspace with a WorkspaceRunner to batch run your exising workspace.
Here's a starting point for more information: https://knowledge.safe.com/articles/1469/batch-processing-using-the-workspacerunner-1.html
  • December 7, 2017
lau
Forum|alt.badge.img+3
  • December 7, 2017
Can you make your groups in a first workspace and use a WorkspaceRunner to run your groups separately?
helentait
  • December 7, 2017
But how do I pass in the different attribute values? That example uses different inputs each time via the directory reader. I have exactly the same data inputs each time, but want to restrict each run to a subset of data using an attribute value.
helentait
  • December 7, 2017
Thanks, but I am still struggling with how I actually automatically pass through a different attribute value each time.
  • December 7, 2017
You create one or more published parameters in the child workspace, these parameters will be available to you in the master workspace and you can map them to attribute values. It should be explained in the article I linked.
helentait
  • December 7, 2017
I'm probably being a bit thick, but I don't think that example helps. It uses a directory reader to iterate through the input files. I want to be able to iterate through values for a particular attribute. I have created the published parameter in the workspace - which I am manually changing each time at the moment - but how do I pass it a different attribute each time? In the example, the iteration is being done by the directory reader - but that won't work for my problem.
helentait
  • December 7, 2017
ok, I think I have it working and it was a lot simpler than I thought. Thanks.
helentait
  • December 7, 2017
Ditto my comment above - I think I have it working with a workspace runner, and a file containing the attribute values I want - passing these through to the published parameter. Thanks
@helentait - can you explain how you got it to work? I'm trying to do the exact same thing. Thanks.
helentait
  • May 3, 2018
Hi, yes @janejane211. So I set up my main workspace and set up a published user parameter for the value that I want to change each time.
I have a csv containing all the values I want to use for the published parameter, each as a separate record/row.
I then created another workspace that reads in the csv file. This is connected to a workspace runner. In the parameters for the workspace runner, choose your main workspace that you want to run. The published user parameters from the main workspace should also appear. Here you can choose the attribute from your csv file
Hope that makes sense.
Yes, Thank you!
